MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/Special:MyLanguage/API:Main_page
action=createaccount (create)
- This module requires write rights.
- This module only accepts POST requests.
- Source: MediaWiki
- License: GPL-2.0-or-later
Create a new user account.
The general procedure to use this module is:
- Fetch the fields available from action=query&meta=authmanagerinfo with amirequestsfor=create, and a createaccount token from action=query&meta=tokens.
- Present the fields to the user, and obtain their submission.
- Post to this module, supplying createreturnurl and any relevant fields.
- Check the status in the response.
- If you received PASS or FAIL, you're done. The operation either succeeded or it didn't.
- If you received UI, present the new fields to the user and obtain their submission. Then post to this module with createcontinue and the relevant fields set, and repeat step 4.
- If you received REDIRECT, direct the user to the redirecttarget and wait for the return to createreturnurl. Then post to this module with createcontinue and any fields passed to the return URL, and repeat step 4.
- If you received RESTART, that means the authentication worked but we don't have a linked user account. You might treat this as UI or as FAIL.
- createrequests
- Only use these authentication requests, by the id returned from action=query&meta=authmanagerinfo with amirequestsfor=create or from a previous response from this module.
- Separate values with | or alternative.
- Maximum number of values is 50 (500 for clients that are allowed higher limits).
- createmessageformat
- Format to use for returning messages.
- One of the following values: html, none, raw, wikitext
- Default: wikitext
- createmergerequestfields
- Merge field information for all authentication requests into one array.
- Type: boolean (details)
- createpreservestate
- Preserve state from a previous failed login attempt, if possible. - If action=query&meta=authmanagerinfo returned true for hasprimarypreservedstate, requests marked as primary-required should be omitted. If it returned a non-empty value for preservedusername, that username must be used for the username parameter.
- createreturnurl
- Return URL for third-party authentication flows, must be absolute. Either this or createcontinue is required. - Upon receiving a REDIRECT response, you will typically open a browser or web view to the specified redirecttarget URL for a third-party authentication flow. When that completes, the third party will send the browser or web view to this URL. You should extract any query or POST parameters from the URL and pass them as a createcontinue request to this API module.
- createcontinue
- This request is a continuation after an earlier UI or REDIRECT response. Either this or createreturnurl is required.
- createtoken
- A "createaccount" token retrieved from action=query&meta=tokens
- This parameter is required.
- This module accepts additional parameters depending on the available authentication requests. Use action=query&meta=authmanagerinfo with amirequestsfor=create (or a previous response from this module, if applicable) to determine the requests available and the fields that they use.
- Start the process of creating the user Example with the password ExamplePassword.
- api.php?action=createaccount&username=Example&password=ExamplePassword&retype=ExamplePassword&createreturnurl=http://example.org/&createtoken=123ABC [open in sandbox]
