MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/Special:MyLanguage/API:Main_page
action=opensearch
(main | opensearch)
- This module requires read rights.
- Source: MediaWiki
- License: GPL-2.0-or-later
Search the wiki using the OpenSearch protocol.
Specific parameters:
Other general parameters are available.
- search
- Search string.
- This parameter is required.
- namespace
- Namespaces to search. Ignored if search begins with a valid namespace prefix.
- Values (separate with | or alternative): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
- To specify all values, use *.
- Default: 0
- limit
- Maximum number of results to return.
- Type: integer or max
- The value must be between 1 and 500.
- Default: 10
- suggest
- Deprecated.
- No longer used.
- Type: boolean (details)
- redirects
- How to handle redirects: - return
- Return the redirect itself.
- resolve
- Return the target page. May return fewer than limit results.
 - For historical reasons, the default is "return" for format=json and "resolve" for other formats.
- One of the following values: resolve, return
- format
- The format of the output.
- One of the following values: json, jsonfm, xml, xmlfm
- Default: json
- warningsaserror
- If warnings are raised with format=json, return an API error instead of ignoring them.
Example:
- Find pages beginning with Te.
- api.php?action=opensearch&search=Te [open in sandbox]
