MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/Special:MyLanguage/API:Main_page
action=options
- This module requires read rights.
- This module requires write rights.
- This module only accepts POST requests.
- Source: MediaWiki
- License: GPL-2.0-or-later
Change preferences of the current user.
Only options which are registered in core or in one of installed extensions, or options with keys prefixed with userjs- (intended to be used by user scripts), can be set.
- reset
- Resets preferences to the site defaults.
- Type: boolean (details)
- resetkinds
- List of types of options to reset when the reset option is set.
- Values (separate with | or alternative): all, registered, registered-checkmatrix, registered-multiselect, special, unused, userjs
- Default: all
- change
- List of changes, formatted name=value (e.g. skin=vector). If no value is given (not even an equals sign), e.g., optionname|otheroption|..., the option will be reset to its default value. If any value passed contains the pipe character (|), use the alternative multiple-value separator for correct operation.
- Separate values with | or alternative.
- Maximum number of values is 50 (500 for clients that are allowed higher limits).
- optionname
- The name of the option that should be set to the value given by optionvalue.
- optionvalue
- The value for the option specified by optionname. When optionname is set but optionvalue is omitted, the option will be reset to its default value.
- token
- A "csrf" token retrieved from action=query&meta=tokens
- This parameter is required.
- Reset all preferences.
- api.php?action=options&reset=&token=123ABC [open in sandbox]
- Change skin and hideminor preferences.
- api.php?action=options&change=skin=vector|hideminor=1&token=123ABC [open in sandbox]
- Reset all preferences, then set skin and nickname.
- api.php?action=options&reset=&change=skin=monobook&optionname=nickname&optionvalue=[[User:Beau|Beau]]%20([[User_talk:Beau|talk]])&token=123ABC [open in sandbox]
